drivers side 1/4 window rubber has split letting in water is there a replacement available please if anyone knows?
11's
11's
thank youI had the same problem and could not find just the top rubber part, it's all part of the quarterlight/window guide assembly.
I got a replacement assembly from a breaker. Dead easy to fit, from memory just three bolts - one on the bottom of the door, two at the bottom of the glass
