2.8 Exhaust Flapper Valve - Disconnect ?
Xertuk
Kingston Upon Hull - Yorkshire
Spent the evening reading with interest about the exhaust flapper valve fitted to one of my twin tail pipes - is it a no-brainer to disconnect and plug the vacuum line for better sound low down, or does the sound of it opening around 2500 rpm make for a better experience ? Or does it screw up low rpm fuelling ?
Thoughts please people !
Chris
Wilko58
2.8 Individual Fiji Green
Disconnect it and try it to see if you like the different sound. ;)
Xertuk
Thanks for your thoughts people, can't imagine it would unsettle the fueling at low rpm so will have a tinker over the weekend. Does seem rather pc to fit it in the first place !
Xertuk
Took a while to locate the control solenoid, anyway it's behind the left hand rear quarter cover inside the boot. Here's a pic to show location and mod - as you leave the pipe in place on the butterfly looks slightly neater.
Wilko58
I don't think people go to that extent, they just remove and plug vacuum hose.
Xertuk
Yep Wilko, agree they will. I wanted to trace the location of the solenoid so made sense to mod there when it was located. Hopefully the image may help others locate the solenoid if required.
2DunnsZ3
Canton USA
Z3 2.8 5 speed roadster
my 1997 doesn't have it. And if you heard mine you would definitely disconnect
