2013 BMW Z4 GTE
For the first time in the American Le Mans Series, BMW’s racing efforts in GT will center around a car other than its M3. BMW Motorsport officials announced Saturday that BMW Team RLL is turning to the BMW Z4 for the 2013 ALMS season.
Technical Specifications BMW Z4 GT3.
Transmission: six-speed sequential sport transmission, operated via shifting paddles mounted on the steering wheel, multiple ZF Sachs clutch
Brake system: hydraulic dual circuit brake; monobloc multi-piston light alloy brake callipers, innver-vented steel brake discs, seamless brake balance adjustment (front and rear) by the driver
Wheels: BBS forged aluminum wheels, front axle: 12,5x18“, rear axle: 13x18“)
Engine type: Eight-cylinder, V-configuration, four valves per cylindre, mandatory air restrictor (2x29.4mm)
Capacity: 4,400cc
Max. output: approx. 480bhp (with mandatory air restrictor)
Max. torque: approx. 480Nm
Titan
North North Yorkshire
sDrive35i
Huh!
All those buttons on the steering wheel and it hasn't even got an ///M badge :(
Can you send them on of yours aceman?
Aceman
Wakefield
///M Roadster
Its got the M colours on the rim as straight markers though. :D
board
Staff member
M Roadster
what does the "Fancy" button do ?
Jamezee
Peak District
Very nice but it is the wrong colour :(
Titan
sDrive35i
I wouldn't object to a blue n white n red n fancy button Z
Sent from m'iPhone using TappetTorque
Jamezee
Peak District
Go on then, I agree but you would think they would throw in a cup holder :coffee
Titan
sDrive35i
I'm not fussed about the cup holder but an armrest would be nice ....:)
Z
zedonist
Titan said:
Huh!
Erm.... It's on the spoiler...... Lovely motor they should make the body kit available, would require a garage extension mind! :coolsteer)
Titan
sDrive35i
zedonist said:
Titan said:
Huh!
Erm ... I meant there isn't one on the steering wheel
Erm ... And how is the driver supposed to see the one on the spoiler and know he's in an ///m ???
Titan said:
zedonist said:
Titan said:
Huh!
Does the ///M badge on the windscreen not count :-\ ;)
