3D Printed Double Din Fascia (Pic Heavy)
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Hi,
I recently bought myself a Z4 and really wanted to update certain aspects of it (check out my project z4 thread).
I love my Pioneer SPH-DA120 so intend to design a Double Din fascia as I have a few 3D Printers. Due to the printable area size, the fascia will be printed in 2 halves but then would be glued together with epoxy weld for example. The front could then just be vinyl wrapped for a quick easy "finish". -- At least for now, I'm hoping to raise funds for a larger printer by selling some bits I no longer need so that I can get a printer large enough to print these pieces as 1 part
The design is currently in progress. I've taken the design idea from a few pics posted amongst forums and off google images.
Let me know what you think :)
Here is an early screenshot of the design:
And here is a preview of it "in place" My measurements were a fraction out so the left couldn't fit it flush but it was a very early print test for exactly that reason.... to check sizing :)
After actually fitting the fascia I had printed, and putting my pioneer head unit into place - I realised I had a fundamental flaw in the design. This is mainly due to fact that the DoubleDin unit can NOT match the angle of the trim area. I had also added a curve to the fascia to match the curve of the trim but due to printer limitations in terms of quality of the print, I then removed the curve and kept the "flat" face.
After trying a fit with the cage in place AND the head unit itself, I realised the cage walls needed to be at an angle
Also, due to my current printer constraints and the way in which FDM printing occurs, there was very little strength where the edges of the cage met the front of the fascia. After trying numerous print orientations and settings to increase the strength and some discussion in a 3D Printing group, I decided to print the walls separately and use JB Plastic Weld Epoxy to affix the wall/edges to the fascia front.
In terms of the fascia itself - I feel like I'm pretty much complete. In case you're wondering, people have mentioned to me that they would like the option of with or without vents, hence why the "vent cutouts" are visible in the screenshot. I Can either delete the cutouts and print the fascia WITHOUT vent slots, OR, I can cut out the vents from the fascia and have the vent slots as seen in all the pics. I personally prefer and want the vents. I have added OEM fixing points, the cage fits my walls perfectly, it all fits nicely in the dash...
(Not pushed in flush at this point)
I also needed to design a way to redirect the air now that I've chopped the vent back in order to fit the double din stereo.
Here was my first attempt:
However, having just recently printed this and fitted it, I came across a few obstacles I had not accounted for.
When I fitted the printed design, I realised it was too low. It needed to be lifted by a good 25mm. During testing, I did this by simply propping a 25mm block under the vent, directly on top of the metal bar.
When it then came to re fitting the sat nav screen, because it's very deep height wise due to the motor, it would no longer sit flush, it was infact about 5mm off the dash and could not go any lower in place.
then came a second problem - of which I can't physically see due to lack of space - but upon lifting the vent, there appears to be what I can only describe as an "overlapping" joint. Eg, a part of the vent goes down, and fits INSIDE another part of venting, without any actual seal, clip, etc etc. This meant air was largely escaping as this joint that I had now separated by forcing the vent up 25mm.
This meant I had to completely rethink the design... I now intend to try this....
I also need to then make a joint from the bottom of those "feet" to the vent exit itself in the fascia. I designed these below after a few trial and error with some other simpler designs.
They fitted great and did the trick
Only problem is I ran out of ABS & PLA (at least enough to complete a print) so I am currently awaiting for more rolls of ABS to arrive so that I can print out and test my new vent design above.
I have also decided to remove the sat nav entirely as it's redundant with the new stereo, but instead either leaving a gaping hole or buying a non-sat nav dash, I decided I wanted to utilise the space as a kind of tray / caddy / little dash storage area.
Pretty happy with the design, and think that's pretty final now. As mentioned, I would really love to get a larger build area printer so that I could print in one piece.
Here is the item printed in PLA just to check size and fitments etc. (Ignore that it's in blue, that's all I had - also, in case you're wondering why not use it in PLA - PLA is NOT suitable for car usage due the high temps the car cabin area can reach. PLA warps and goes soft and pretty much gets ruined, ABS or a similar material is required for in car use)
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Thanks all. Once my batch of ABS arrives I can continue my progress. Whilst I've been waiting, I've been looking at making my own wind deflector instead of forking out hundreds :).
Will post a new thread in the next day or so with the deets :)
Pingu
I use superglue to glue 3D bits together.
What software do you use to design with? I found the best was 3D Builder that comes free with Windows 10. All the others that I have looked at just over-complicate things (K-I-S-S) ;)
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Superglue isn't always ideal as the bond can be broken easier than an epoxy.
I use 123D Design on my mac. I don't get on with fusion 360 etc.
Pingu
I've not done anything in ABS yet, just PLA.
I've read that you can use acetone (nail varnish remover) to glue ABS as it melts the two parts together. No idea if true.
I'll google 123D Design :thumbsup:
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Yes you can acetone weld as well as acetone smooth etc. I've used it before but not a fan of using acetone.
For in car items you really need ABS as PLA can't withstand the heat inside the car and warps. Unless you live in somewhere that never goes over 5 degrees you'll be safer with ABS.
Trouble with ABS is it's a pain in the a to print with. Prone to warping and layer splits etc - you really have to have your printer dialed in nicely and enclosed too!
123D Design is discontinued now but I believe you can still find downloads for it easy enough.
Pingu
Seems to be Tinkercad on line now. Do you recommend downloading an old version of Autocad 123D, or registering and using the online version?
You answered the question before I asked it :).
LOL at the warping. I made a mobile phone holder and it has warped in the sunlight. It was fine until the first really hot day, then it went all soft and pliable. I heated it with a lighter and got it resembling the original shape. It works (sort of) !!
Alchemy !! :thumbsup:They used to burn witches for this kind of trickery.:ymdevil:=))
I'll wait for the finished articles guys, way over my pay grade all this.:)
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Tinkercad is alright. Although I don't like "online apps" plus tinkercad was too basic for me. As an example you can't do chamfers or fillets. Google around I'm sure you'll find a download somewhere! If not I'll locate 1 for you tomorrow
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Haha. Put simply its the program used to draw the design. I just need my ABS to arrive to restart printing.
Been down your neck of the woods (Peterborough) this evening James, maybe one day I'll get there and see what you're on about mate.:)
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
Peterborough isn't exactly my neck of the woods. It's 45mins from me in Cambridge although depending on your route you may have passed Cambridge if you went up the M11
Redline
Nuneaton
E89 20i msport
Impressive work. I can see you getting some orders for these parts when you have fettled the design.
Double DIN units seem to be more numerous, especially if you want certain features.
TaffZee
Near Llangollen North Wales
Z4 3.0 SE
Is there a way of retaining the computer data to show on another device, i.e. fuel consumption, as by removing the sat nav screen the computer info wont be shown anywhere, I was going to replace the screen in the pop up with a Tablet, but then realised the info would be lost?
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
You can use an OBD reader & an app on your phone such as dash command or torque whereby it can keep track of fuel consumption etc. The consumption data itself I don't think comes from the obd I don't think. Dash Command calculates it from other factors and data but when I had it in my other cars it was pretty spot on
IAmOrion
Cambridge, UK
2003 Z4 E85 3.0i
3D printing has the added bonus of customising features too :) eg vents or no vents, maybe a USB socket or a branding logo or whatever
