I'll be removing the engine from my '99 Z3 next week if all goes to plan, in order to replace it with an electric motor. I need to keep the transmission, clutch and flywheel but the rest is going spare. Happy to sell it all as a unit or break if there is demand.
Probably going to throw it up on eBay but thought I'd post here first if any UK and particularly Northwest/Greater Manchester peeps need relevant parts.
It's the 1.9l unit - M43 I guess? 174,000 miles on the clock but runs (mostly) fine. Can share a video of it running. I say 'mostly' because there's a vacuum leak and a split in the air intake hose, and I think the secondary air pump is borked as well. But everything else seems good.
Full list of what's on offer when I get it all stripped and confirm which parts I don't need, but you can assume everything that goes with a combustion engine will be going, including the exhaust (no holes that I can hear), alternator, starter, etc.
Not priced it up yet but if there are parts you want/need then give me a shout and we can work something out.
