AC Schnitzer E85 M Parts Advice/Info Help Pls
Felix79
Hereford
Z4MR
Hi guys,
as some of you might remember, over X-Mas, the bracket/joint/clamp on one of my back boxes rotted away, as well as the lip being a bit worse for wear, which ended up with a garage making a new joint/clamp on the effected section. I know it's likely some time this year I will have to replace the back sections with my M.
I've been looking at the AC Schnitzer E85 M back boxes, some of the wheels (the larger 5 spoke wheels, rather than the thine ones they did for the Z4) and the suspension sets. I've never really had much interaction with their products, bar the odd bit see on E30 members cars and I nearly got an E36 that had a ton of stuff on years ago. They can be very Marmite and I think they exhaust systems they do are actually the most tasteful thing they make. Has anyone got or have any experience with these bits for the M? I don't want a loud exhaust, but if it would just liven things up when I'm up in the rev band, I am really interested.
Cheers,
Felix
Sorry, no help with the AC Schnitzer exhaust but interesting reading that you had a failure in the joint, I had the same thing last year and had all 4 flanges replaced and used a new aftermarket clamp.
Looks like this may be something for other Z4M owners to look out for.
