adhesive sealer for around back window
Johnnywheelnut
Suffolk
Somewhere I have seen a tube of sealer adhesive for the hood trim around the back window but I cant find a reference to it in the forum now ,I can see something called goo in the USA but is there an equivalent in the UK ?
mrscalex
Swindon & Swansea
I've seen a professional soft top specialist use regular clear silicone to stop a leak to try and avoid having to replace the top as well after doing a window only replacement.
If you want to glue the edge down where it's shrunk back from under the beading then Stormsure is popular.
