Hello all and thank you for taking the time to have a look at this thread.
I bought my Z3 back in 2019 as a bit of a project car. Currently it is pretty much totally stripped (not the inside) as i work my way through a few repairs and maintenance. I removed the rear subframe yesterday as most of the bushes have failed and again I am part way through the dismantling process. I am looking to order some parts for the rear differential and the brake pipes fitted to the trailing arms.
Q1 - How do i identify the type of Diff i have (Z3 1.9L Built July 2001 M43 Typ CM12). It has a sticker on the top, i have attached a picture but everything else is covered in rust! there is no separate metal tab with a part number on. Real OEM has 2 part numbers listed for diff, with lock and no without lock. My car does have ASC if that helps.
Q2 - The brake pipes fitted to the trailing arms are looking quite tired. Would somebody please give me a steer as to where i might find the correct part numbers for replacing. I presume they are still available?
Q3 - If i were to change the drive shafts, other than BMW what would most people recommend as an alternative?
Q4 - What is the external and internal diameter of the rear wheel bearings, I have come across 2 different sizes which state they both fit my car, 75 ext and 42 inner and there is 72 ext and 39 inner. That's quite a difference.
For me, this website has been invaluable and i have really enjoyed working on my car. When finished i will probably be in around the £10000 - 15000 mark for a car that's worth 20% of that if I am lucky - That said its not about the money and it is fun, just don't tell my wife!
