Advise please
ExMX5owner
Staff member
Australian Zeds
Queensland, Australia
Nice looking Z Martin, My favorite colour. I can't help you identify the problem, but I,m certain someone else here can.
Welcome to the forum anyway...:thumbsup:
Yeah, welcome from me too. There are a lot of Z3 1.9 owners out there who should be able to point you in the right direction.
MartinJ73
Few more pics of my Z3. Took me a while to find such a clean example with on 31k miles
Pontrhydyrun
Z3 M44
Welcome. I have the same car as you. Same engine. But I've just looked at mine and I can't figure out your pipes.
Is the leak (if it is one) coming from the narrow metal tube? Or is it leaking somewhere else and just collecting in that corner?
On my car there's narrow pipes (half inch or so) in front of the radiator. They don't follow the same route as your's but, in my case, they are power steering.
But when I wash/hose the car water does collect around that area.
Check the liquid. It it oil or water?
MartinJ73
Hi thanks for reply, its coming from where pipe meets that box shaped junction. Feels like power steering fluid. I shall continue to investigate.
colb
Newport, South Wales,UK
M44 Engine 1.9 if that leak ois power steering fluid check out the rubber hose ends where they clamp to the reservoir and the rack. Rubber tends to rot away and develop leaks. If they have factory compression clamps on once you get them off replace with some stainless jubilee clips with new hoses.
Ianmc
New Forest
Z3 (M44)
The power steering cooling pipe does suffer from rust. If its original, could be the problem. :thumbsup: About £100 for my last one.
MartinJ73
Turned out to be air con pipe. Fixed with some sealant supllied by local independent Bmw specialist. Thanks for help folks.
2.2 & 3.0 Sport
Hi Martin and :welcome: to the forum from me too in Stafford. Pleased you got it sorted.:thumbsup:
