I wanted to cover my Z3 for winter.
So I attempted to unscrew the aeriel. ?? Should be removable, right ?
Problem is the bit that unscrewed was not the bit I expected, see pic.
Anyway this leaves me with a problem;-
1. New Aeriel, same as the old, that I beleive is expensive ?
2. No aeriel, block up the grommitt hole.
3. Different aeriel ?
know the aeriel is an often discussed problem so which way do I go ?
Also if the wire inside the top is detached has anybody effected a repair as the body/case seems pretty well sealed
