ian rosewell
- May 12, 2013
Hi folks
My b800 reset tool has always managed to reset airbag light in the past but not this time. The b800 comes up with table38 code fault 2 "warn lamp" but the scroll function on the b800 has stopped working so can't clear the fault.
I have checked the bulb which of course works otherwise the lamp would not have illuminated in the first case.
Any ideas?
Also my engine management light keeps coming on. The Indy has replaced 2 lamba sensors due to the fault code coming up but now the code is suggesting camshaft sensor is the issue. This sounds expensive has anyone else had this issue.
Thanks
Ian
Z3 roadster 1999- 1.8L
Any ideas?
Thanks
Ian
