After water penetration I got the dreaded red airbag light on.
Insta+ reported "93D7 ACSM: Internal control-unit fault".
After installing an identical replacement Insta+ reported "S0180 No communication possible with: Safety module/ restraint system".
Assuming the replacement module was faulty, I installed another identical one , only to have Insta+ report "S0180 No communication possible with: Safety module/ restraint system" again.
I reinstalled the original module and Insta+ reported "93D7 ACSM: Internal control-unit fault".
So, another replacement sourced and installed only for Insta+ to report "S0180 No communication possible with: Safety module/ restraint system" again!
I find it hard to believe that I have received 3x replacement control units each with the same fault, albeit provided by the supplier, however by re-installing the original unit and re-confirming the original fault that is what the evidence implies.
Anybody had this experience or any ideas what could be going on?
