Airbag light on the cluster
Z3Mroadster
Z3M roadster,airbag light working on the cluster....
Wires under seats are ok...
What else is maybe problem?
Jjim
Mansfield
1.9 Roadster
Have you tried resetting the light, and if so does it come straight back on?
I had a similar issue and found it to be the connection to the driver occupancy sensor. So moved the chair forward, turned the ignition off, disconnected the yellow/black connector and blew in it to remove any dust and then reconnected it. Then I connected the code reader up again and started the engine and wiped the error.
After restarting the code went.
It seams that sometimes a loose connection can cause this issue.
Most likely the pre-tensioner if all the wires are OK, had the same problem on the M, code reader will tell you
