Hi all,
My car is locked, but the lights flash intermittently flattening the battery!
Any ideas anyone ??
Tia
Any ideas anyone ??
Tia
Hi Ian thanks for that-where is exactly???Assuming this doesn't happen when the car is unlocked, my first point of call would be the under bonnet sensor switch. Try disconnecting it and see if the problem goes away. If so, fit a new switch.
Ahem, borrowed from another Forum ....Its on the bonnet slam panel, near side front.
Yes I’ve disconnected it! However others mention an anti rock/tilt switch in the boot and also a movement sensor in the cabin.
He said it’s a Battery Back Up ???Try the bonnet catch first. Suck it and see. Did he explain what a BBU switch is? IIRC the tilt sensor lives in the LH boot well?
