So what is the expert opinion of the above? Are they any good and if so why don't manufacturers fit them?
They coulda gone extra billig und just had 4 studs. (Or french and have just 3)Hub and bolt are two parts as opposed to a three-part stud application; the hub, stud, and nut. Therefore, cheaper.
Ze Germans ztarted zis as X thousands of vehicles times 20 studs each is expensive.
Und wir müssen effizienter und billiger sein! ja?
I think the keyword (or words) is "depending on supplier". There's a lot of pretty looking cr*p out there. Posh looking spanners and sockets that break as soon as you look at them. Can't see why there shouldn't be the same problem with wheel bolts. Personally I'd feel safer with hex caps on the heads. Unless I knew of a reputable supplier.Yes, again I know all that, but the question I'm asking is are all the so called 'alloy' (won't rust - advert) versions inferior to those fitted by the manufacturers. Should we just keep the inevitably rusty bolts and fit 'caps' to improve appearance or are the 'alloy' (I'm using the term as used by the suppliers) ok? Difficult to know exactly what you're getting I suppose, depending on supplier.
I'd make a bolt for it if I were youYou’re all nuts
Is a cake an alloy, or an 'amalgam' of different things?On a lighter note, here's a picture of a cake, which itself could be described as an alloy of flour/butter/sugar/baking powder and many other things.
