Angel eye projector fogs
board
Staff member
M Roadster
i've been deliberating whether to go for the ccfl rings in the OEM lamps or go for the replacement units with the projectors and just came across these as i was browsing around.
board
Staff member
M Roadster
Cool, they look nice. I bet it looks quite mean at night with all the rings on:) No fogs on the Ms so can't add those
stevie_a
Glasgow'ish
Looking at the front of your car, i see you have removed the orange indicator lens but did not fit the white lens ( at £90 i am thinking twice on this option)
It looks good but does it work ok??
as in does it emit the light bright enough ??
a photo at night with your lights on are in order i think.. B-)
Zteve
Rothes
E89
Hi stevie_a
The head lights were fitted at the same time, they are complete replacements from eBay...Item number: 230410167841
All I changed were the bulbs for Chrome, they passed the MOT last year...
May just try a night time photo...when the weather settles... :ymblushing:
Same lights but not chrome! The change with these projector lights is the difference between night and day. Bought mine through Simon at JustRoadster.com. Cost about £250 for the units including the main bulbs. Switched mine for chromed indicator bulbs for a nicer look!
stevie_a
Glasgow'ish
I just seen these on e-bay, look interesting.
clicky photo
stevie_a
Glasgow'ish
Question :
My car does not have front fog lights, is it a case of just buying a switch with front and rear and the fog lights
and the wires are all sitting behind the switch and fog light blank plates?
or will i have to wire it all up?
stevie_a said:
Question :
There is a good chance that all the wiring is in place (I think the cars have a standard wiring loom), have a look behind the blanking panels where the fog lights sits, the wires should be there.
If the wiring in place, it is just a case of adding a switch & lights etc.
