dt7734
- Apr 14, 2017
Quite fancy a set for my motor....
Thanks for the info guysI also thought to Rondell 0058, I have no knowledge of them being fitter OEM on the E39 at some point but it might be.
If that's the case you might be looking at an ET20 8J for the front and ET26 9J for the rear, if I am right and they are ROD wheels the it's ET13 8,5J at the front and ET15 10J !!! at the rear.
Having the facelift you will be totally fine at the rear, with about 20mm of extra stickout, but they will not fit at the front, unless you want to go outlaw and possibly install some limiter for the steering.
Ok-ThanksOff set on a z3 front no less than at 35 at that width and that may protrude a little @13 they will stick out way to much at the front unfortunately
If the wheels stick out beyond the front arches I guess it will look hideous and probably illegal.serious poke on the front with that size
me tooQuite fancy a set for my motor....
...and dangerous.If the wheels stick out beyond the front arches I guess it will look hideous and probably illegal.
If it doesn't stick out further than the mirrors, does it really matter?...and dangerous.
