I have a Z3 2.8 1997 automatic
When I drive it from cold it drives great good gear change and smooth.
When I stop the car and switch off the engine then restart it drives off but on th 3rd gear change it jumps (feels like under the seat) then I get the engine management light on.It dose not go into limp mode just jump on high end gear change it feels like it jumps into gear.
If I switch the car let it go cold it runs fine again.
I have been told it could be a switch on the gearbox but unfortunately these switches are now obsolete
I am waiting for an adapter for obd so I am not sure what the fault code is.
I will take the car to a garage but not sure on a local garage that would be good with an old car.
Has any one had a similar problem?
