Hey guys with this colder weather Victor appears to have developed an issue.
I initially thought it was a bad battery and have replaced, however its happened again. Does anyone know of any common issue with the z3 issue as follows.
Battery flat. Jump Starts fine without issue and a quick 15 min trip to work is sufficient to restore power to the battery. Ie I can from having bump started 15 mins later, start the car via the ignition. As stated I have changed the battery thinking the cold weather was causing issues. I think this leaves me with 3 possibilities.
1. New battery could also be bad.but I doubt it.
2. Alternator is not doing the job as well as it could be?... how do I check.
3. Something is draining the battery that shouldnt be. Any thoughts?
Thanks.
Mark
Thanks.
Mark
