Yes I have bought a eibach adjuststable coil over kit but I need warmth as well as a bit of blue sky before they get fitted.Wheelsl ook great any plans to Slam it Slam ? Sorry that was a terrible pun but would look great with a little height drop
Totally agree with you I love the look of ants car. I have a set of coil overs to go on but when it's a bit warmer. I bought these wheels last year and thought I had better see if they fit ok before I start messing with the suspension.Agree with Ant, wheels look great and compared with Ants blue car lowered to perfection, yes it could do with dropping a little.
The adjustable coil overs are much thinner than a standard coil over so clearance should not be an issue.The key to the coilover and wheel fitment will be the front offset a coilover body will sit a lot lower than a standard strut it's the clearance between the spring and the wheel that is key and it may require the fronts to be spaced to fit them.
I looked in to coilovers but I would struggle to get the front to fit without spacers and I'm pretty flush already so decided on the bilsteins instead
The offset of the wheel rim could still make it very close. Hope they fit though.View attachment 74110
Hmmm I don't know then , I thought it was the platform that usually gets to close to the tyre with when the offset is to high. Time will tellThe offset of the wheel rim could still make it very close. Hope they fit though.
Yes it does look nice and shiny in the photos but it hasn't been washed and it needs one it's actually pretty dirty.Great wheels you have
Very smart
You Z looks very shiny and clean too
