Hi Guys,
My mechanic has changed everything relating to miss fires and it still wont fix the problem. My car is a BMW Z3 2001 2.2 (E36). Below work has been done and in the respective order as well:
1. Air flow meter changed
2. All 6 spark plugs changed
3. All 6 ignition coils changed
4. New head gasket installed
5. Engine flused and complete servicing done.
Once the engine was flushed the car was running fine for a few miles with no irregulaities. The mechanic told me to rev more than normal so that the new oil flows through completely. After about 10 miles the same problem appeared. When the car was idle on a traffic light it started miss firing and the engine light came on as well. The problem goes away if I switch off the car and switch it back on after a minute or two. I can see that I am not getting the same output from the engine which should probably be becasue of the miss fires.
My mechanic is inclined towards getting the ECU out and send that for repairing. All of the repairs up till now have cost me a fortune (£400) and sending the ECU for repair will be another couple of hundred pounds.
I am not sure, as the mechanic is going through hit and trial basis which is not working. I was wondering if someone has had the same problem. I am happy to hear any ideas that people think should help because at this point I do not trust my mechanic anymore.
Any help will be much appreciated.
Thanks,
Saad
Thanks,
Saad
