SOLD BMW Z3 Cruise Control
I have a cruise control kit for all M54 Z3’s and M52TU engines. Basically if you have flyby wire Throttle body it will fit. These are plug & play all done locally under the column plastic cover.
Price posted £125
Great price, there is a guide on here to fit too 😉
Sold thanks everyone.
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Lee, @Lee
Are these the only bits one needs if you have a M52TU engine (manual)? I fitted those parts (Cruise control switch - 61318360926; Button for cruise control switch 61311390968 and Interface, cruise control 65718380054 ) and for one reason or another it don't seem to be working. Am I missing something as I read somewhere something about running it for 50 miles before the system recognises it also another article (bimmersport.co.nz goes on about the clutch switch - where do I find this?). Just in case it helps VIN is WBACH32060LE91497 (build date 11/98)
Thanks,
Ade33
Stratford upon Avon
3.0 Sports Edition
Wasn't any good to to me this "For Sale" when posted as I didn't own a Z3 then :)
If anyone has these cruise control components for sale that fits a Z3 3.0 M54 unit please get in touch thank you
gookah
Shropshire
2.8 Z3
Lee, @Lee
Thanks,
check the outer brake light bulbs have not been changed for LED type, they will stop it working.
  • Agree
Reactions: Lee
Lee, @Lee
Thanks,
To answer your main question, yes all you need is this item.
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
YEp I've got them fitted... any ideas about the need to run it for 50 miles? And do i need the clutch switch?
MuttyMax
Woking, Surrey
1.9 M44 and 2.8
Many thanks - no box standard.
Brocky61
Winchester
3.0 Auto
Mine's an automatic so I believe this isn't required as I don't have a clutch?
Ade33
Stratford upon Avon
3.0 Sports Edition
Just about to install the same on my M54 3.0 manual... Am I correct that the above doesn't apply to mine and its just a matter of plugging in the interface and stalk switch?
  • Agree
Reactions: Lee
