Now there will be horrified people who read this, but when your down to one car and it needs to be a "used" and "abused" car because its all you've got.. Then you start to look at Mods that keep your enjoyment with a bit more than just our smug smiles......because we know the cars we have.
So I Have fitted a really nice Tow bar. Mod. The Roadster can only pull up to 1/2 tonne. No more because if you did go heavier you would damage your chassis. Which if you have never seen it is below in the pictures. It is not a heavily built chassis making it lighter.
Watling motors do a special bar assembly that is really subtle. All you see is the square section under the rear bumper for the removable tow bar. There is no need to cut the bumper which is good. This is a WIP and I am still assembling her after a strip down and re-spray. But this is the Tow bar fitted with the bumper off. Before the spray up. It took 2 hours.
The good thing is now I can pick up bigger stuff in a lightweight trailer (like you could with an estate) opening up more opportunity to drive her for small tasks .
Towing Weight limit here though must be adhered to. I think you can apply this mod onto roadsters to 1998. though you need to check..
More Pics to this ... As part of the strip and repaint I went round the body looking for areas that had corrosion caused by the design. The worst parts were where the Boot drains down over the rear light assemblies.
So a bit of welding, filling and repainting were in Order. The good thing is that none of the spraying and wax oiling can be seen when the bumpers back on. Subsequently I think the work done may prevent future work.
