I've noticed that when I open the boot, the opposite side of the boot (inside top) is wet. Is this a bad break light seal? Is it hard to change? Is the dealership the only place to get one. Frankie
I'll give it a try. If I understand what you're saying, you're using the same gasket, but added some silicone to it?Hi Frankie,
I had the same problem.Some of the plug in bulbs had failed so I replaced those and then teased out the light unit.It's easy to clean up the gasket and the hole it fits in to,.then applied a smear of silicone sealant. It sealed nicely (checked this by pouring water over the unit with the boot closed) No leakage since.
