Box in boot ?
Texaroo
Bradwell, Norfolk
3.0i
Hi, I am just looking to buy a Z3 3.0 but need to fit wheelchair in boot, have noticed that some Z3 s have a box hanging from left hand side which will restrict height. Can anyone tell me what this is and if can remove ie if CD player, it has a trim around it and I have noticed that some Z3 do not have this but do have electric roofs so don't think it is the roof motor. Have noticed some have CD player underneath this trimmed box. Any help would be very much appreciated.
roadvoyager1
Shotley Bridge
2.8ltr
It will be the multi change CD unit. You can remove and replace with a dash mounted unit if required. Boot trim without the box come up from time to time. Check with @spursfan to see if he has one.
spurs fan in a coupe
It is either a CD changer, there will be an opening on it somewhere to put the CDs in, or an amp. Meaning that it probably has the HK stereo system in it, which is saleable.
The pump for an auto hood is tucked in the left hand corner by the rear light cluster, under the aerial.
Yes you can remove the carpet, then the stereo equipment and re-fit the carpet, it will have the hump still, some people just cut the hump out and live with it, other get spare parts of the carpet from somewhere and make a patch. Or you can get a new (or second hand) piece of carpet from a Z3 which never had the hump.
These do come up from time to time, cost £40-50 but I don't have one at the moment.
Enjoy the new car when you get one
Texaroo
Bradwell, Norfolk
3.0i
Texaroo
Bradwell, Norfolk
3.0i
Thanks to all for replying to my post, really nice you took the time to help me out, any chance someone can measure the boot space,height,width and length as I need to get wheelchair in unfortunately, need to know max height with box removed as well as width and length. Also any common faults with Z3 3.0 I need to know about.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
Hi and welcome to the forum :p
From Bradwell near Great Yarmouth :)
stevie_a
Glasgow'ish
Welcome
I would be surprised if a wheel chair would fit in the boot if it did you would not be able to shut it
you could put it on a boot rack
  • Like
Reactions: Rha
Best option, have you got the wheel chair? Where are you located? If you're anywhere near a member ( who has a hump less boot carpet) I'll bet they would allow you to try it for size.
I certainly will if you are anywhere near Lincoln.:)
Bozzy
Long Eaton.
:welcome: from Nottingham. Just to say i'd offer help with trying a wheel chair in the boot for size same as Tony if your near me.
@Texaroo where are you located ?
Texaroo
Bradwell, Norfolk
3.0i
Cheers mate appreciate it
Welcome @Texaroo just to help us out a bit, what is the size of the wheelchair?
in Bradwell
We have a member from Bradwell, @Shelly, but theirs is a Z4, but they might know someone local who has a Z3. Failing that there will be someone I'm sure.:)
DavidM
Ireland
Welcome from Ireland! I hope I am proved wrong but the wheelchair may not fit in the boot nor on a boot rack without interfering with the rear window, although, I have seen a few very compact looking wheelchairs when folded down.
