Brake Calipers
Brian4
Near Grantham
Z3 3.0i Auto
I've got to change the front discs and pads soon and looking at the calipers they are all rusty. I was thinking of painting them all black whilst I have them apart, thoughts anyone.
Brian
si-forks
worcester
I'am also interested in what people have used as mine are just big rusty lumps
Si-forks on tapatalk
Frank.A
Twixt Hull and York
2.8 Facelift
A good wire brushing and a coat of Smooth Hammerite is as good as anything. ;)
DangerousDave
I don't think that normal Hammerite will take the heat. I used Halford's Brake Caliper Paint.
If you can, remove the caliper to paint it. At the very least take the pads out, unbolt the carrier (#2) and remove the rubber bushes (#12).
I'd also suggest that you paint the pads the same colour as it looks really strange having pads that are a different colour.
Aceman
Wakefield
///M Roadster
Unless you intend tracking your car and expect to overcook your brakes from time to time then Hammerite smooth is the way to go. I have also seen calipers painted with a mix of gold and silver hammerite which gives the same finish they came out of the factory with.
swamper
Bacup
M
mine have been painted with Hammerite for over 12 month and still look ok
Titan
North North Yorkshire
sDrive35i
I used engine enamel on the calipers but only because it was already in my garage.
For the hub part of the discs I have used both silver and black smooth rite without any problem.
The best effect though if you can lay the car up for a few days is powder coating.
I think Shantybeater did this and someone else but I can't just recall who.
Z3nt from m'iPhone on Tapatalk
Frank.A
Twixt Hull and York
2.8 Facelift
Hammerite has been on the Passat calipers since I bought it new in 2003,no problems. :)
B
badman gee
just painted mine yesterday.
nice and blue.
i used stp caliper paint.
no brush marks, dries with a gloss finish.
:D
S
Sorcerors Apprentice
nice and blue.
:D
And here is a pic...
B
badman gee
Sorcerors Apprentice said:
nice and blue.
:D
nice!
you get better apprentice, id love to meet you. same soh!
B
badman gee
painted mine on the car, didnt remove them.
came up a treat.
blue calipers with red pads looks like the m badge!
Brian4
Near Grantham
Z3 3.0i Auto
Thanks everybody for your replies and as si-forks says they look rusty blobs, so I will go the hammerite route when I change the discs and pads.
Brian
billz
Langley Mill
Like Titan (terry) i also use Engine Enamal. With a couple of coats the crap then just wipes off.
bill
