NigelM
So the roof isn't working on my Z3M. I did a search on here and following the advise I found that the brake lights were not working either pointing to a problem with the brake light pedal switch.
What switch shall I buy from where and before I do so is there anything else that could be causing both problems (fuse 46 is fine).
Thanks for your help. Nigel
