So, a full list:
ABS pump, the old type with the ECU behind the glovebox £35.
ABS ECU - as above £20.
Aerial module - it looks as new. SOLD
Badges for the bootlid and bonnet vents - I have two £10 each. Some small marks but pretty good. SOLD
Body control module behind the glovebox £30.
Atlanta blue rear bumper in very, very nice condition. Replace your tatty one for £50.
Diff - zero backlash and super clean 3.45 ratio. Fits 1.8 1.9 2.0 and 2.2 £200.
Door check straps £20.
Drivers door lock with solenoid £30.
Door pulls SOLD
Door striker £15.
Driveshafts - 1.9 narrow body only and as tight as a drum £35 a side. ONE ONLY, ONE SOLD
Engine - clean and a very nice runner SOLD
Fuel pump SOLD
Front undertray SOLD
Front hubs with ABS sensors, wheel bearings etc - fit all Z3's. The 18mm bolts all came out. £50 a side.
Front struts - standard 1.9. mildly rusty but low mileage and not leaking - £50 the pair with springs.
Gearbox Fits1.8 1.9 2.0 and 2.2 SOLD
Gearlever boot, black kappa leather £20.
Glovebox lock £20.
Grilles, very good condition SOLD
Heater valve £20
Hood - original BMW with a very good rear window. SOLD
MAF - proper Bosch. £40
Mirrors are broken - 20 quid each for parts.
PAS oil cooler loop - nice condition and I've cleaned up the few rust spots and painted it. SOLD
PAS pressure hose from the pump to the rack in exceptional condition. 1.8 and 1.9 only £80.
Propshaft SOLD
Steering rack sold.
Seats - black leather in very good condition. Working motors, no front-back play and unbroken belt guides SOLD
Door cards to match above, without the handles. SOLD
Speedo SOLD
Steering wheel - 3 spoke standard type, fits early cars until mind/late 1998 SOLD
Switch blanks (narrow type) £whatever
Trailing arms - superbly rot free. The drivers side had a bad wheel bearing so I removed the hub flange Good backplates. SOLD
Wheels. Yeah, the usual Starfish things, one or two good tyres and some kerbing. £60 or I'll remove the tyres and weigh them in.
Window motor, passenger only £25
X brace - again, really nice and rust free. £80.
Others: tail lights, passenger side repeater, window switches, calipers, passenger door seal, boot seal.
No window regulators, good mirrors or panels.
