For Sale BREAKING; 1997 Z3 1.9
Andyboy
SHEFFIELD
121,000 miles, Arctic silver with an...er......unusual retrim.
Genuine Rondell 8x17 wheels (ET35)m refurbished with new budget 215/45 tyres. £600.
Most of the panels are knackered. The hood will go again (manual) but the window is shagged.
Non ASC brakes.
It's had new discs and pads and a lot of time spent overhauling the suspension - new track rods, wishbones, coil overs etc.
New exhaust.
Genuine catalytic converter.
Notts NG17.
Andyboy
SHEFFIELD
I've sold a few bits already but plenty left.
Airbag module £20
Bonnet vents £30
Boot latch £10
Calipers £25 each
Coil pack £20
Cylinder head £200
Exhaust manifold £50
Flywheel and clutch £40
Gearbox crossmember £20
Handbrake lever £10
Master cylinder £20
Pedal box £50
Propshaft £40
Rear trailing arms £250
Rear lights £20
Seats £70
Short engine (perfect bores and crank) £150
Steering coupling shaft £20
Undertray £50
Arch liners £40
X brace £50
A few other bits of trim but nothing else. No panels or sills etc.
Andyboy
SHEFFIELD
Sold: steering rack, exhaust, diff, MAF and ABS block.
Jane Booth
Cheshire
2.8 automatic
Hi Andy
Would those seats have the black plastic backs I’m after?
Jane
Andyboy
SHEFFIELD
I have no idea!
Andyboy
SHEFFIELD
Sold: gearbox and steering coupling shaft.
Andyboy
SHEFFIELD
They’re horrible though. A shitty retrim - I’ll end up taking the motors out and skipping them tbh.
rosey1955
Hi
Do you still have the wheels/tyres for sale? If so whereabouts are you? Thanks
Andyboy
SHEFFIELD
Long gone, sorry.
Andyboy
SHEFFIELD
They are.
Newbieowner
West Sussex
Z3 2.0
do you have the boot interior trim available? Am looking for the rear panel (up against seats) without a CD changer hump
You will need the side panel too to look tidy as the humped version side panel is cut to fit the hump. Also I believe there are two different versions of the side panel, one for manual soft top and one for a powered soft top with the bulge for the pump. You will need the correct one depending on your soft top.
Andyboy
SHEFFIELD
The short engine has sold, cylinder head still here.
Andyboy
SHEFFIELD
Airbag module £20
Bonnet vents £30
Boot latch £10
Calipers £25 each
Coil pack £20
Cylinder head £100
Handbrake lever £10
Master cylinder £20
Propshaft £40
Rear trailing arms £125 ea.
Rear lights £20
Undertray £50
Arch liners £40
X brace £50
