Hi, could anyone tell me if the Carly code checker/programmer would code my Z4 (metal folding roof) to close. The key fob only opens it.
Thanks
Thanks
Just needs the 3rd party module for it to close off the fob but it is extremely expensive for the e89This can't be done with the Carly to a standard E89. I believe it requires the Comfort Access Pack or a third party roof module.
The E89 roof will only open from the key fob.
Not heard of that method before. What's the process?You can close it from the outside using the key in the drivers door lock
Agree if you are putting the roof up when you stop, I don't always if I'm parking on the drive and its a hot day.Although it's probably just as easy, and more comfortable, to sit in the car for a couple of minutes longer and close it using the button.
