All done
. Swapped the Yaw Rate Sensor over and got rid of those dreaded lights. Great result.
The cause of the problem was a build up of water. After taking the drivers seat out and lifting the carpet I was greeted with a pool of water covering the floor and a sodden sponge(?) layer. Two nights and one day of a de-humidifier going full blast has cleared nearly all of the damp, but next spring the seats and the carpet are all coming out to be thoroughly dried. Although, in the meantime I shall be on the look-out for newish, if not new, carpets.
As a precautionary measure though, I have sealed the plug unit with silicon sealant where the wires go into the plug, then wrapped the plug and socket in a piece of rubber pond liner, about 3 or 4 inches long, bound with amalgamating tape. And, as a 'belt and braces' ploy, another one foot square of liner between the carpet sponge and the unit. Also, the Zed is going in for some re-spray wok in about a months time, where it will be in the 'oven' for a few hours with the hood down. Hopefully, this should help dry out the rest of the damp.
I suppose the question should be; where is the water coming in? I guess with a 'soft top' it is to be expected. But I would welcome any pointers as to a solution if anyone has had similar things happen.
All in all, though, I am very pleased with the result and if this remedy can help somebody with the ' three light dilemma', then I'll be really chuffed
As an aside, I am going to take the old unit apart and check it over for where the shorting occurred, for that is the obvious result of the water ingress, whether I will be able to find or replace any components that have failed I am not certain. But as I have a reasonable electronics work bench in my 'playroom' and thirty odd years of trying to electrocute myself, and not succeeding, it gives me a tiny glimmer of hope! If I do succeed I will post the results on the forum.
Cheers for now, Colin.
