- Mar 15, 2015
I thought you might like to see some images of your off side door handle from the inside
On the edge of the door is a small plastic blank. Remove this and using a screwdriver push this bar in as far as it will go.
to this position as below
Using a small screwdriver carefully prise the rubber away from the door as above and away she comes
Replace the rubber and reassemble. once the handle is back in the door using a small hooked item pull the bar towards your self and replace the blank.
Now make your self a brew
