Changing headlight bulbs
Cammy
Removing the bulb holder I tried to remove the bulb it won’t budge and I don’t want to use excess pressure in case I break the bulb.
Any ideas? Help!!!!
colb
Newport, South Wales,UK
Z3 Headlamp bulb TIS says turn and pry it out.
2.2 & 3.0 Sport
Mine are HB3 and HB4, to remove them they rotate about 30 degrees and then just pull out. There are no clips holding them in, it's a bayonet type connector.
Perhaps a photo of the back of your headlight may help us to help you.
Cammy
Mine are H7 I rotated the holder removed it and pulled the connecting plug of. The bulb won’t come out the holder. Do I need to buy another bulb holder£55 each !!!!
Pictures would help. You can see it, we can't.
2.2 & 3.0 Sport
H7s are normally held in with a wire clip arrangement which you unhook then just remove the bulb. You do not rotate a H7, in fact you cant due to the locating lugs on the base of the bulb. We definitely need a piccy;)
Stevo7682
Maybole , South Ayrshire
If your bulb looks like this then that is how they come
One is a 9005 hb3 60w main
Other 9006 hb4 55w dip
The 3 prong fit rotates 30 ° or so to remove and refit.
The 3 prongs are one way round only and the 2 bulbs ( dip and main ) have a slightly different 3 prong pattern and are Not interchangeable.
Stephen.
