Cleaning the roof rain sumps
zee4me
hey everyone, any good tips for cleaning out the roof top rain sumps? I am going to take on the roof motor relocation project but wanted to know if there are any suggestions for cleaning the muck out of of the sumps without removing the soft top. any tools that are particularly useful?
lucky jim
blaby
z3
i did the same thing i was unable to push up from the drain outlet but with the motor out soapy water & bottle brush & flush both sides out it out from the top but don't worry to much it depending where the car is parked you get all sorts rubbish down there.
colb
Newport, South Wales,UK
Use something long and flexible to rod the drains out from the bottom under the sill and use soapy water as @lucky jim suggests to clear the drains, probably best to relocate the motor to the boot first. Once you manage to cut the tie wrap(s) holding the motor case in there it should lift out so you can wrangle it back into the boot.
Good video guide here
View: https://www.youtube.com/watch?v=NPhwOO654JA
zee4me
Thanks, for advice. i think i decided to pull the soft top off to do a thorough cleaning of sumps, drains, and to relocated the motor (which is currnelty not working). more work, but probably needed in a 2005 vehicle with 90K miles.
