You need to put a code reader on it to see what code(s) have been set.
Usual cause is a wheel speed sensor, code reader should tell you which one has failed, replace and clear codes, lights should go out after the car has been driven.
Hi and to the forum from me too in Stafford, England. As said above you need to get a code reader on it otherwise you'll end up just throwing money at it.
