B
bonzo
Hi all. I guess as Zelda has an alloy engine, it's a good idea to regularly replace the anti freeze/water mix in the radiator to prevent corrosion as well as it's anti freeze function. What would you techies out there consider that interval should be? And can you run through the procedure for this, and the bleeding technique and anything else I ought to know.
Cheers m'dears
Bonzo.
Cheers m'dears
Bonzo.
