Ctek- Under bonnet E89
Im looking to put my Ctek MXS 5.0 from my Z3 onto my Z4 for a few weeks. However I have just looked under the bonnet and the cables are not long enough to go from the live and the negative. Can the negative be any metal? What type of extension do I get if not?
Below isn't my car but shows the distance between the two
Ha, if you meddle blindly with these cars something bad will happen...But I am hoping you are correct and someone on here can confirm.
Back when I did my apprenticeship an earth was an earth, I realise things have changed but if a strut-brace isn't attached to some thing solid then there's no point having it.
I have no idea about cars, so you are 100% ahead of me
Pond
Spaldingski, Lincs
Z3 project and E89 Z4
I always attach the earth to one of the suspension strut tower nuts on the nearside. The offside ones are attached to the same place as the earth lug, so the nearside is exactly the same. You will know if you have a decent earth, as the charger will light up. If you haven't it won't.
Ctek do specific extensions which plug straight into the lead, but a waste of money IMO.
B21
Scottish Borders
E89 35is
I’d go with one of the 3 nuts on top of the strut mount on the LHS..then both DC cables will have a short run..
Thank you, I will look at that tomorrow. Can I just secure the eyets with tape?
Pond
Spaldingski, Lincs
Not knowing where the battery is on a Z4 don't help, but I've got a few of these on my bikes, saves taking seats off/unbolting bits for access.
The battery is in the boot, but the E89 needs to be charged from the terminals in the engine bay, due to some overly-complicated nonsense called IBS (not irritable bowel syndrome but Intellligent Battery System).
A charger can be hard-wired but it is a bit of a faff because of the terminals. It is possible to shut the bonnet with the standard crocodile clips attached.
Argyll Andy
Argyll
Z4 - M40i
Top green positive, yellow negative, bottom green for connecting charger :thumbsup:
Argyll Andy
Argyll
Z4 - M40i
Is that using the standard cables ?
On one of my E89’s yes on another I used below. Same length of cable iirc but both cars long gone.
In case you haven’t investigated yet, there’s a hole already there on the positive terminal that you can nut and bolt the ctek too and still use the red plastic cover fully. HTH :thumbsup:
In case you haven’t investigated yet, there’s a hole already there on the positive terminal that you can nut and bolt the ctek too and still use the red plastic cover fully. HTH :thumbsup:View attachment 321287
Thank you, I will be looking to sort this today
I have attached to the live with a nut and bolt and also on the strut there was a smaller thread that the eyelit could fit on so added a nut to that. Temp job for now, but will make it more permanent when I'm back. Thank for all your help
