Door card removal trouble
Major Dude
I had to replace my broken door pull on my 1999 Z3 Roadster. I did research to see how to remove the door card. Everything went as planned but there use one section I am unsure about. When I removed the door card a plastic section that is located behind the speaker remained on the door. I honestly wasn't sure if it was supposed to be part of the door card or stayed on the door. I couldn't find any mention of that anywhere. I'm thinking it must have been part of the door card. It has a little plastic door that unsnaps but during the process I apparently snapped off those little tabs. Now that corner of the door panel does not fit tight. Any suggestions?
