Dropped on it's arse at last!
Barry78
Edinburgh
Z3 2.2 M Sport
After a few false starts...pishy Ta Technix coilovers and then even pishier Ta Technix shocks i learned my lesson and just fitted Apex -35mm lowering springs to the OE shocks.
I like the look but could grow tired of the speed bump rigmarole.
I hadn't personally lowered any of my cars before but when @Craig Giblett done his i had to have it done. Far to much air between tyre and arch!
Coupled with the Poly lower rear wishbone bushes, the 2 x new wishbones and 4x new balljoints, the 2 x new droplinks, the 5mm spacers all round, 2 new front top mounts, 2 new rear top mounts and once it has its new boots on the front it'll be off for a geometry/alignment set up.
Been a busy few months of ownership! :thumbsup:
It's how they should look, why BMW added the agricultural wheel gap in the first place...
As for speed bumps, it's just something you will get used to. I can only go 10mph over the ones near me as I drag my front spoiler... :(
Barry78
Edinburgh
Z3 2.2 M Sport
Used to curse the wee chavs in their civics doing that all over our village when behind them...i'm now one of them at almost 40!!!
Grumps
Forest Town, Mansfield
Z4 e85 2.5i
Looks really well. I'd like mine lower but with 18's on and to bigger J rating i can't as it would catch on the front springs.
spurs fan in a coupe
The coilovers on mine mean the front have to have massive spacers - so you're right only a fairly narrow J rating possible
ZTec
Llantwit Major
Looking good, getting used to mine now after picking it up from the Zed shed yesterday.
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
The wheels would still sit below the bottom cup on the damper and shouldn't be anywhere near the spring.
Grumps
Z4 e85 2.5i
I can just about get my fingers between the cup and inner top of the tyre.
g8jka
Telford, Shropshire
The shorter spring will just make the damper shorter, not the distance between the bottom of the damper and the cup meaning you should still have the same gap, unless I'm mistaken!
Craig Giblett
Edinburgh
Sport
We are now experts are Bmw z3 suspension swap outs... We've only done it 5 times between two cars in the last three weeks and unless these bilstein b8's on mine start to play ball and give me the drop I want they might be coming back off!! ;)
Craig Giblett
Edinburgh
Sport
Grumps
Z4 e85 2.5i
OK I see your point. Makes sense mate, Thanks.
