Robz3sport
- Nov 13, 2015
Ordering a clutch for my 2001 2.2i Z3, when I enter the reg number it tells me that my car has a dual mass flywheel? Is this so? Do all z3's have these as standard?
A lightened flywheel isn't about the weight, it's about how that weight is distributed. I've known a lightened flywheel that was actually heavier than standard .Agree Tony. I have a single mass fitted to mine which is lighter (14.5kg down to 9.0kg) then an upgraded clutch disc for all the track abuse.
That don't make much sense to me, it's all about the weight... I have a lighter fly to allow the engine to rev more freely, the standard fly is really heavy. Also remove the clutch delay valve that really allows you more control over the clutch delivery.A lightened flywheel isn't about the weight, it's about how that weight is distributed. I've known a lightened flywheel that was actually heavier than standard .
A single mass, lightened flywheel with braided hose is probably as good as you can get at a reasonable budget.
I understand this concept but just not sure how it applies to this thread.I understand what @Pingu is on about. It's all to do with rotational inertia. If the mass is at the outer radius, then you have more rotational inertia.
Two single mass flywheels that weigh the same but of different designs with the mass spread differently will have different rotational inertia. The one with the mass concentrated nearer the center will be better for faster acceleration.
There is a Youtube video somewhere that talks about this. Could not find it quickly to provide a link.
Could be. It will reduce it. I do know that the immediate effect of going to an SMF is more chatter in the gearbox caused by torsional vibration.Were DMF's not something to do with controlling crankshaft tortional vibration? I seem to recall stories of crank failure following replacement of DMF's with a SMF in some applications.
This one I think Tony https://zroadster.org/threads/m44-dual-mass-to-single-mass-and-beyond.6167/This was a project which Richard, @Zedonist was doing on his 1.9 Z3 before he left the forum a few years ago. Never did get to see how it turned out, he was working abroad and had to turn the car over to his local garage to complete IIRC.
