- Feb 18, 2016
- Model of Z
- Z3M Imola and Z4 (e89)
If like mine your e89 wasn't specified with the OEM deflector and like me you decide to retro fit here's a word of caution. Second hand parts can be hard to locate as breakers seem to be removing the deflector but not the fixing brackets and hoops etc, so here is a tip.
Information on the upgrade says you need the correct rear facing roll hoop covers to be able to fit the deflector kit and these have a different part number to the standard ones. So I assumed that there are differences in either the shape or structure of the covers so duly ordered a pair of OEM covers (at £22.40 each, not a fortune I know but its a lot for parts you dont need). There is a difference but not what I expected....see below.
The only difference are two 7mm holes drilled in the cover for the screws to pass through to secure the deflector bracket to the roll hoop You can drill these into your existing covers without to much difficulty.
So in short you do not need to buy special modified hoop covers to fit the deflector kit onto your e89 just measure and drill 2 holes in each and can save some money. BMW have had an email from me and I received an apologetic reply and the offer to return the parts.....do you think they know it's a bit of a rip off?
All you need is the deflector and the mounting brackets don't bother hunting for second hand brackets you can get them on line for £2.80ish each The deflectors range second hand from ebay auctions selling for £100 to £150. if you see one make an offer, I did and got one for £80
Just thought I'd share.
