Ebay. Trickle Charger Solar Panel 1.5 Watts
Low Rider
SORN Zeds need to be kept charged so I was thinking this would be a useful bit of kit.
But what are your thoughts about the charger ?
Not that a Zed is SORN.
I bought one of these a few years back but did not have too much success with it, I had a feeling that it drained the battery more than charged it, they are supposed to have built in protection which stops this so maybe mine was duff?
Low Rider
Was you charging direct to the battery or via the 12v socket ?
I used the croc clips direct to the battery, one thing I never checked was the running current of the car when not in use, I suppose if the alarm etc. uses more than 1.5w then the battery will always discharge. Don't suppose anyone knows this figure do they?
Redline
Nuneaton
E89 20i msport
I suspect these things only kick out 1.5W in bright direct sunshine. Do you get that much sunshine?
No - thought not :whistle:
Low Rider
You might be right about the amount of sunshine but surely some charge is better than no charge.
Redline
Nuneaton
E89 20i msport
It depends how good the electronics on it are. A poor design will likely drain more when its dull than it supplies when its sunny. I'm afraid usually cheap = nasty. If they were that useful surely manufacturers would fit them as standard?
Rha
Z4 coupe sport.
I know this is old hat from last year but bought myself a starter /batt booster cos although I was starting my Z quite regular I sometimes left it for nearly a month and Z batt only just managed to start it, so the booster was a good buy. After it got me out of trouble a few times I thought why not use it like a charger if pos :wacky: so even though I went round to start the Z more regular knowing it would start on its own, I took my fully charged booster every time hooked it up and left it a few minutes to feed Z batt, :bag:then used it for initial start right through the winter,:happy: this summer the batt showed good resilience to being left for periods up to 5 weeks when I was busy doing other things.:meh: Obviously its a lot more expensive than a charger but I can take it anywhere with me and help others with start/batt probs. OK!!! people round here think I must have a duff batt but I've never had to bump start it (which has probably left them scratching their heads) just have to make sure booster is fully charged at least every 3 mths when not in use. That reminds me better charge it up.:bookworm:
Took the Z out yesterday when I got a couple of hrs off DIY and it didn't rain, miracles do happen :rolleyes:.Rha,Roy.
M
M666BMG
If your going to buy a charger for all year round, buy a CTEK.
They are excellent.
Nifty Fifty
Wylye
Put mine to bed at the end of Sept, so its been a couple of weeks and went to give it a turn over this morning and as expected, dead as a DODO!!:(
So will have to pull the battery out and give it a good charge and then invest in a trickle charger. TBH not in any real hurry with Xmas fast approaching, on a positive note at least no one can steal it!!
