Electric Polisher.
andyglym
Just got this through the post, I'll give it a whirl later in the week. As much as I like polishing manually this will take the pain and time out of tight areas, especially with the flexible attachment and pads.
First thing to do is stretch out that cable and let it sit for good while to get the kinks out of it Andy, otherwise you can end up polishing out scratches from the cable rubbing on paintwork.
Tony
Jack Ratt
The West Country
TRURO, CORNWALL
2.8i AUTO and 2.8i MANUAL
I've got one of those flexi attachments with my Dremel and they really a great addition. I like the way you can hold it like a pen to get into fine areas, holes etc. I used one with a fine grinding wheel bit to clean the hole on the back of my front hubs when I fitted new speed sensors. You can do the job without it but why struggle? You have so much more control too
billz
Langley Mill
Can get a decent polish now you have a machine :whistle:
Mazza
Bognor Regis
Don’t get confused and pick up an angle grinder.......:whistle:
First thing, get used to putting the cable over your shoulder, is it direct drive or da
Direct drive mate.
Excellent, a proper polisher but be aware yoiu can do some serious damage, your biggest risk is panel edges and body lines, on panel edges make sure the spin is away from the edge, meaning that the mop is spinning off the panel toeards the edge if that makes sense
andyglym
Cheers mate, noted :thumbsup:
gookah
Shropshire
2.8 Z3
Is there a guarantee?
I would get a replacement. that one looks all blurry,
andyglym
Is this a mini one with the 1", 2" and 3" pads? I've been looking at a similar one on Amazon but it hasn't got that flexi attachment. Have you got a link to this one please?
Hang on ....
andyglym
g8jka
Telford, Shropshire
Z3 - 2000 2.8 Roadster
andyglym
Thanks, that link has just come up with a load of different products. But as you mention SPTA it's the same one I was looking at :thumbsup:
3rd and 8th products down are the flexi lines. One for £47 with a gazillion pads and one for £8 just the flexi line
billz
Langley Mill
I would get a 3" Backing plate and pads to go with it. Can deal with swirls better
billz
Langley Mill
I would not bother with the AG Swirl removers. Get a decent set designed for this sort of work such as Menzerna or 3M and the likes
