How To Guide Emissions Air Pump Tube (11721404626) for less than £10
Pingu
S50 Engines only
The tube goes from the air filter box to the emissions pump. If the hose fails it can be replaced for less than £10, not the £100 that BMW want.
RealOEM
ECS Tuning - their price is usually very close to the BMW price.
The original pipe...
The repaired pipe...
Use 28mm radiator hose (500mm length found on eBay for £4), some jubilee hose clips and a 28mm copper elbow from B+Q (£2.13).
The removal and refit is a bit of a faff, but the best way to do the job should be obvious to anyone who attempts it.
Hopefully, this post will help you save some dosh that can be used on Shell Nitro+:thumbsup:
