Anybody know if the condenser on my Z3M S50. Is it the same condenser as the other large engined Z3s? I.e. the 2.8. Or the 3ltr engines? Or is the M version specific to the M?
TIA
many thanks
TIA
many thanks
yes that’s what I was thinking! How different can they be?Yes. It is unique to the S50B32 engine, but that doesn't mean that something else won't fit.
It would be very strange if it’s not a generic part as there aren’t many parts specific to the z3m some suspension and exhaust parts and and a few bits of plastic. I’ve a problem with mine and it’s going to need fixing so keep updatingHave you run the part numbers through realoem? Whilst not definitive it’s a good start for alternative models. lllparts.co.uk is also good for dumping part numbers in to check cross model fitment.
Echoing what Pingu says about S50 specific, had the same with the power steering pump on my Z4M. Looked to be unique to the Z4M but actually same as used on the E46 M3 and Z3M with the S54.
