Adding extra air for the benefit of the simota. This came about as i was looking through the bimmerforums reading plenty of discussions on air supply.They all seemed to come to the conclusion that the ram effect was the best for the simota induction kit to function at its best. I have had several pm`s with Mike Fishwick who also has a write up on his air supply addition ,which is very interesting. But with mine being the M version i wondered how, with the cone of the Simota jammed up against the back of the headlight, could it be enough air for such a big filter.
Removing the 4 screws holding headlight in place.
There is an airway to the left of the headlight but as it is blocked off when you close the bonnet what good could that be doing. The only way that would help was if you were to put an extra vent to the right of your bonnet grill and i dont think that would look good. I have at this time removed the headlight and already i have found a great fix.
The 2 wires that belong to the left rear of the light are coming through from the engine bay connected to a square of plastic which is connected to the actual plastic cowling which is fitted behind the headlight. I removed this square to find the simota now has twice the exposure to air. I now believe with the addition of a air supply pipe to the left hand vent,(the one which i think is not doing its job) the flow of air would be considerable. progress reported as and when completed
