Hi all… bit of a lengthy problem with a few questions so please bear with me.
My Z3M (S50 - 1998) has started with an intermittent misfire issue which takes down the whole of bank2 (cylinders 4,5,6). No warning lights come on and the issue eventually rights itself but has started returning often. The car is now with my local indie garage who managed to get a reader on it while it was under the issue and his code reader read 151 MSS50 CONTROL MODULE FAULT - DRIVER FAULT
However while googling the issue for any fixes I came across this website http://www.bimmerboard.com/forums/posts/1229818 which lists many codes for different engines and models - it does list the Control Module Fault against the S50/E36/Z3M but it also lists 151 KNOCK SENSOR 2 as a fault code against the S50 engine albeit in the E36 model (Not Z3).
I am hoping that it is the knock sensor that’s faulty and we are going to try and test this by swapping Knock Sensor 1 & 2 around and hopefully the fault will move to bank 1. However in the circumstance that it is the ECU that’s got an issue….
Q1. Has anyone ever had any of these issues before?
Q2. Does anyone know anywhere that can test /fix the ECU module?
Thanks Lee
Thanks Lee
