Fault Code Reader / Reset
Chazzy
Northampton
Can anyone recommend a fault code reader which will fit a 1999 Z3M which can also reset any faults once they've been fixed?
Thanks
joepig
preston
Thanks GazHyde,consider another one sold,can't have enough toys
It's more that it's at least half the price that an independent garage will charge you to read them, and a small fraction of what a dealer would charge. You may not know what the fault code is when you find one, but you've saved a ton on your diagnostics to start with! More money for the replacement parts, or beer - whichever fixes it first =))
Cooper
Australian Zeds
Hobart Tasmania Australia
3.0i 2001
I just ordered one of these after reading a recommendation form the members. I took option #5 for my car. Great price and seems to do everything, read and reset and program eveyy module!
www.bcables.com
Dickymint
Somerset
Z3 2.2i Sport
+1 for the c110 its a great bit of kit and easy to use :) can check all the modules if you use the round adapter :)
pgunter
Winchester
2.2i Sport Zedshed Special
I have used the C110 and it works fine. I also have purchased a WiFi connector that goes into the cable adaptor so I can diagnose faults using my iPhone. The software is available free online. I always though go back to using the C110 to main resets, Airbag lights etc.
Hugo
If you check several sellers you'll find some sell both cables as a set for the same price as a single cable. HTH. JIM
Zeti
Romanian Zeds
Bucuresti/ Romania
Z3 roadster 1.9
I've used one and it's very straight forward to use.
In the item description says is for '97- '02. It works for a '96 1.9 for sure?
