How To Guide Fix Seat belt Guide
Andy Z
Newport South Wales
Z3 1.9
found a great solution for the seatbelt guide repair.
I used a strip of numberplate tape cut about 8mm wide and fixed it along the outside line of each side of the broke guide so it came to the edge but not protruded out to show.
Moved the 2 broken ends out of the way and stuck one side down either side of the double sided number plate tape, the peeled the other side and pulled out slightly and move the 2 broken half’s into position then pushed them back,
Then I slid down the support cover over the gap where the seat belt can be inserted or removed.
This little perfectly molded piece of Black ABS plastic can be purchased off eBay as a fix which is brilliant but you also need to fix the back pieces to the seat or they will still move and prevent seatbelt sliding back and for smoothly.
Hope this helps guys,
Let me know if any
More info required.
Shelly
Norfolk
Z4 2.0 20i M Sport sDrive
:scorecard: Good to see that you posted your seatbelt guide @Andy Z
