As I said "Making a difference" , and lo and behold today a prime example.
I tested a Hyundai Getz at lunchtime and the emissions failed badly on high CO. The owner was disappointed as he'd just "thrashed" it up and down the by-pass.
Almost 3 times the limit after a full Cat test and oil temperature taken. The man then puts in a bottle of Forte petrol treatment and gives the car a blast up the by-pass. When he returned I completed exactly the same test as at lunchtime with an improved reading on fast idle CO but slightly raised idle CO as below.
Only 2.3 times the limit now, so he said I'll give it on more go and if that fails it's scrap (not wanting to fit a new Cat) Another bottle of Forte and another run up the by-pass, last chance saloon,
Same test, same oil temperature on 2nd fast idle test (full Cat test) and it passes, albeit on the limit. No new Cat and only £30 spent.
May not work for every vehicle but this proves that it can and does work.
